ce qu'en pense un pro ...
Message par lou_passejaire le Lun 5 Déc - 17:51
Rubicon Models a écrit:There had been a lot of debate about whether 3D printing can actually replace plastic, resin or metal miniatures. As a design studio, we would like to share some of our thoughts.
Q: Is it now?
A: Definitely NOT now.  Still not cost and time effective enough to make 3D printing viable.
Q: How about those low quality 3D printers?
A: If you are looking at low end 3D printers at the USD400 (GPB320) to USD1000 (GPB800) price range, forget about it.  These printers are basically copycat of each other with a different look with the similar mechanism and software.  At 28mm scale, you are practically printing a block of melted plastic with extra-long cleaning time to make it looks like what you think it is.
Q: How about those mid-range 3D printers?
A: If you are looking at mid-range 3D printers at the USD2,500 (GPB2,000) to USD6,000 (GPB4,800) price range, those can do some decent work, but don’t expect any fine details.  You will also need a lot of cleaning up to do afterwards.
Q: How about those professional grade 3D printers?
A: How do you define “professional grade”?  Don’t trust advertising or printed samples… they are VERY misleading.  Send the manufacturer your own file and let them print it out with their printers.  You then compare the results before making a decision.  These printers can cost between USD64K (GPB51K) to USD130K (GPB103K).  The way manufacturers tell you about “resolution” is also very misleading too… and make sure the printer have the “printable” size you wanted.
Q: What else do I need?
A: You must at least know how to “draw” in 3D before even thinking about making your 3D models.  Knowing “how-to” is very different from being proficient in creating printable objects, plus the time to create them!
Q: What do you expect from a 3D model?
A: Quality – had to be true-to-scale, true-to-details, and historically correct.  Read a lot of reference material, and locate as many blueprints as you can find.
Q: What do you expect from a 3D print?
A: Quality (again) – no zig zag lines, smooth surface, and fine details will show up where they are supposed to be.  You must expect long print time for any good quality job.  Some will take over a day to print… make sure you have enough raw materials to finish the job.
source
scratch
Re: ce qu'en pense un pro ...
Message par WhiteWolf28110 le Lun 5 Déc - 19:59
Oui mais en français çà serait mieux ... cyclops drunken cyclops
Message par Siaba le Lun 5 Déc - 20:19
En gros, l'impression 3D de masse à la maison, c'est pas encore ça....en tout cas, d'après eux, c'est pas prêt de remplacer le plastique et la résine.
Je résume mais ils évoquent le rapport qualité prix qui est encore favorable à la résine et au plastique.
Siaba
Message par Panoramix le Lun 5 Déc - 21:20
... et surtout de la qualité du produit fini même en utilisant une imprimante professionnelle très très chère: pas terrible.
Message par naash le Lun 5 Déc - 21:42
Pour avoir acheté quelques trucs sur shapeways, en ultra frost detail, je dois vous avouer que la qualité devient très correcte et qu'il faut avoir le nez dessus pour voir les couches d'impression.
Au toucher, peanuts, nada, walou...
Après, ça n'est pas donné mais quand on aime... Embarassed
Voici quelques photos pour vous donner une idée:
Un ATAT au 1/270, à côté d'un Xwing (pour l'échelle)
Le même de plus près, désolé pour la qualité de peinture (il a été retravaillé depuis...).
2 autres vaisseaux (le plus gros fait plus de 20cm de long)
Et un ARC 170 (de très près, en vrai il fait 5cm d'envergure à tout casser...).
Tout ça pour dire que oui, on n'est pas encore au stade où la 3D supplantera nos figs en plastique/résine/métal, mais qu'il y a quand même des trucs sympas qui ne verraient pas le jour autrement...
Message par lou_passejaire le Mar 6 Déc - 1:13
ben quand on voit le prix des imprimantes permettant des résultats de qualité pro ... on comprend que le produit sorti de l'imprimante soit foutrement cher ... on amortit pas des investissements de l'ordre de 50 à 150 000 € facilement ...
donc économiquement ce n'est viable que pour la production de "prototypes" pour une exploitation ultérieure en tirage résine, métal ou plastique ...
